weird front end shake still
Old Sep 21, 2009 | 02:17 AM
trackjunkie08's Avatar
Default weird front end shake still
so i swapped out my pads and checked my rotors, they look spec to me. still however, i have a shake in my front end that goes away after about 45 mph. its more prominent during braking so possibly a warped rotor? just wondering if there are an other small things to check before i pay for a new rotor.
Old Sep 21, 2009 | 06:00 AM
pacemaker's Avatar
Could be a warped disc, but you usually get a "pulse" coming the the break lever, also a bit of noise as the disc goes through the rotor. Have you checked the play in your steering head bearings? that can give a similar scenario.
Old Sep 21, 2009 | 07:18 AM
MartiniRossy's Avatar
Bent/damaged wheel, bad tire or unbalanced tire? A warped rotor should not create a shake while you are not braking unless it's so bad it's rubbing on the brake pads all the time and that doesn't sound like the case.
Old Sep 24, 2009 | 05:58 PM
Ruckus1987's Avatar
Check your bushings. I had a similar problem and new bushings fixed the problem.
f4stolenhelp
Sep 23, 2013 05:41 PM
asides
Apr 25, 2010 03:35 PM
pr0jktmayhem
Jun 13, 2009 11:36 AM
Orangebutter
Aug 13, 2007 06:31 PM
Slayer1000RR
Jun 19, 2007 11:46 AM
