front end shake
Old Mar 19, 2010 | 05:43 AM
asides's Avatar
Default front end shake
i have a 98 f3 when im in like 4 5 6 gear and i leave off the gas and let go of the bars the front end shakes bad but if u let off and hold the bars it dont shake. also my stem bearing is shot it wigggles when ya use the front brake. so in thinking that is the problem also have fork seals leaking so maybe way out of fluid. so did i answer my own question
Old Mar 19, 2010 | 09:42 AM
Kuroshio's Avatar
I'd say you need to correct the front end problems you know of and then see what you have.
Kinda pointless trying to figure out if something is wrong when you know something is wrong
Old Mar 19, 2010 | 09:45 AM
Kuroshio's Avatar
Also you realize you've listed enough serious issues to know you shouldn't be riding that bike???
Sounds like she's giving you enough warnings and prepping to highside you for not listening...
Old Mar 19, 2010 | 05:01 PM
pacemaker's Avatar
My bike has always had a slight bar shake (from new) when I let go of the bars. The bearings have been adjusted & it still does it. The answer to that problem is I don't let go of the bars. Lots of things can cause front end wobbles, including a badly adjusted rear tyre, shot swing arms bearings & front/rear tyre balance.
If you know you have RS head bearings & your forks are leaking oil, then its pretty fair to say that you have answered your own question.
As Kuroshio has said, your only one pot hole away from ending up on your ****, so get it fixed yesterday.
Old Mar 19, 2010 | 05:28 PM
ajzcamaro's Avatar
Fix what you know is wrong first, then go from there before you end up on the pavement. Front end problems like that are nothing to just look over, especially bearings.
Old Mar 19, 2010 | 05:59 PM
intiractive's Avatar
Originally Posted by pacemaker
The answer to that problem is I don't let go of the bars. .
exactly. my 89 ninja did the same thing when i would let go of the bars (it only had 8k miles.) so... i didnt let go of the bars
Old Mar 20, 2010 | 01:04 AM
spicymeowmix's Avatar
Official Welcome Crew Spicy Cat
also check your tire pressure
Old Mar 20, 2010 | 01:48 AM
cbrseabee's Avatar
ive been told that tires also wobble when they are in a certain speed. i got dunlop qualifiers on and it wobbles at about 45 to 55. but after that its all good.
Old Mar 20, 2010 | 05:35 AM
asides's Avatar
i have shinko 009 so not the best tires but hopefully after the fork seals and the bearing its all good
Old Mar 20, 2010 | 09:07 AM
marc0011's Avatar
You've probably destroyed the races on the head bearings from letting the front end slap back and forth when braking. When working on the forks, pull off the upper and lower triple clamp. I bet you'll see that the races have been torn up.
