Water wetter or engine ice ??
Old Feb 15, 2012 | 07:45 AM
Ms.mroz's Avatar
Default Water wetter or engine ice ??
Hello, i just drain old coolant from my 01 f4i and still dont know which coolant should i use . Iam from florida ( KW) an its pretty hot here sometimes ! So what would you recoment ? Water wetter or engine ice ? Thanks
Old Feb 15, 2012 | 09:18 AM
this guy's Avatar
I use 1 bottle water wetter and fill the rest with distilled water . It drop my temp gauge down a 1/4.
Old Feb 15, 2012 | 11:53 AM
vfrman's Avatar
Party Animal, ROTM June 2014
For me it depends...water wetter for track and engine ice for the street.
Old Feb 27, 2012 | 08:28 PM
CJardine's Avatar
Track junkie & modaholic
Originally Posted by SuqMa***
It says on the bottle you are supposed to use at least 15% coolant
I did the same and so far the bike really, really, really likes it. I rarely hear my fan kick in now.
Old Feb 27, 2012 | 09:36 PM
wagzhp's Avatar
water wetter or engine ice are good, but you also need anti-freeze for it's anti-corrosion protection. Add the water wetter or engine ice and top off with a 50/50 mix of anti-freeze and distilled water.
Old Mar 30, 2012 | 05:19 PM
GorgeousHellion's Avatar
>> wagzhp. What do you use in your bike? Do you put water, coolant AND wetter?
I know someone that was mixing purple over (or liquid ice- I'm not sure which) and water wetter.
Old Mar 30, 2012 | 05:22 PM
Meant anti-freeze, not coolant.
Old Mar 30, 2012 | 09:23 PM
ekelman's Avatar
I recently replaced my coolant in my f3 with Engine Ice. According to the label on the bottle it is premixed and uses deionized water. It is recommended on the bottle that you do not mix with water. (Don't know about mixing ainti-freeze in with the engine ice) straight from the bottle it should protect to 246 degrees F. Freeze protection -46 F. It was tested in southern Florida and is said to reduce engine temp by 50degrees F. I have noticed that my engine runs pretty cool; but here in New Jersey we have not had any real hot weather yet.
Old Mar 31, 2012 | 01:23 AM
wagzhp's Avatar
I'm running water wetter with BMW premixed 50/50 antifreeze.
Bimmers are my preferred brand of car, but they have notoriously weak cooling systems. They are particular about requiring special coolants that won't corrode the aluminum components in the engine and cooling systems. So, since the BMW brand of coolant is OK for the cars, and I have it on hand, I also use it in the bike.
