Water Pump Seal Question
Old Jul 16, 2017 | 03:19 PM
Chad Sims's Avatar
Default Water Pump Seal Question
Hello All,
I'm riding a 2001 CBR 929rr and recently discovered a pretty significant oil leak and judging by the location of the leak that it was coming from around the water pump. Not sure what the previous owner did when putting it back on the motorcycle, but it seems to be leaking around where the o-ring is and meets the casing and just dripping down the pump. It only leaks after about 10 minutes and the oil drip sheet showed only one area (below the pump).
I ended up just getting a new water pump and o-ring/gasket and want to know if it's recommended to put any type of sealant around the o-ring or where the water pump's two parts come together.
Thanks!
Old Jul 16, 2017 | 10:19 PM
74demon's Avatar
Shouldn't have to if the surfaces are clean and smooth.
But a little bit of silicone sealant around the o ring can be good insurance.
f4izombie
Jul 4, 2011 11:08 PM
cbrf4bp
Apr 27, 2009 10:22 AM
cb2cbr
Mar 8, 2007 11:20 AM
zrad
Feb 27, 2007 11:58 AM
ameersak
Oct 16, 2006 02:53 AM
