W.T.F !! do you get leg cramp's ????
RE: W.T.F !! do you get leg cramp's ????
ORIGINAL: Proeve
Only cramping I get is in the hands. I wish I know how to not get them so fast.. it really take the fun out of riding..
the first one can usually be solved by loosening your grip, softer grips, weighted bar ends, or Stomp Grip on the tank.
the second one I have had problems with in my right hand after I broke a couple bones in it last year. I actually flick my remote control in the air and catch it with the same hand while i'm watching tv or whatever and occasionally use one of those stress beanbag things, just squeeze the hell out of it.
both of those help my wrist and hand a lot.
i normally get them after riding about half an hour, right under my knees at the top of my shin. i strecth my legs straight out towards the front wheel(im only 5'6") or stand up for about 3 or 4 minutes, normally doesnt go all the way away until you get off and walk it off. as fas as the hands, i notice on a sportbike you tend to rest your body weight on the handlebars, so you have to learn to hold your self up instead of resting on the bars.
P, I finally oriantated my levers, in more of a straight plane w/ my arms, easyer clutch and braking.
and about those cramps RR... rear sets can usualy be set lower too, if they have a wide adjustment feature. ride more ,streatching, and those bananas!!!!!!!
try neck exersizes too, to fight higher speed buffeting. my x-pro's, first leathers w/ a speed hump, really help stabilize my noggin. Clean and free, Ripp'n
ORIGINAL: woodyracing
what kind of cramps are you getting in your hands? from weight on them or from using the clutch/brake/throttle?
ORIGINAL: Proeve
