Vacuum Hose Routing
Vacuum Hose Routing
Hello Folks!!! New to the forum here. So let me thank anyone who chimes in in advance. Hopefully the image i attached is clear enough. So the two hoses i have a red line through, that have the red arrows(ish) pointing at them, look like the are just kind of floating around there. Indeed, they are floating about under my tank as well. I just had to pull the starter for a quick rebuild, tight fit in there, and when i went to put all the hoses back together i noticed these two hoses just kind of chilling there. Can anyone tell me if they do actually just sit there venting or if they attach to something. I got her running and covered the left side one and the idle dropped a bit, though she was still cold and idling high. My rides a 2002 600 F4i. Again, thanks for any help on here, just want to make sure i button her up correctly. Safe Riding Buds!!!
The hoses in this diagram are only routed up to near the Throttle Bodies. The end that you can't see is attached down below to the Intake Manifolds as shown in your picture. With the Throttle Bodies removed, they just lay down as shown in your image. When you install the Throttle Bodies, you're supposed to route them up as shown in the image I provided. Where and if they're supposed to be connected to something I can't say at this time.
The following users liked this post:
Blasimoto (11-01-2021)
IDoDirt (11-01-2021)
@Blasimoto Thanks for coming back and posting up. It's amazing how many people don't do that. It's appreciated.
