Trouble w/Light'N Boltz...
Old 11-05-2006 | 11:24 PM
CWRUDI's Avatar
Default Trouble w/Light'N Boltz...
Need some advice on how I'm screwing this up. I paid the d@mn money for those "Light'n Boltz" to be used on my license plate mount after getting rid of the factory fender. (I couldn't find any cheaper versions at the auto parts stores.) I've already installed an integrated tail light that works perfect as well as everything else on the bike. The last thing I had left to do was to wire the "Light'N Boltz" to the original plate light wires. I cut the factory plate light wires the same way I cut the left and right turn signal wires...yet I can't get the "Light'N Boltz" to light up when I splice them in.
They seem to be 12v lights that I can probably just run straight off the battery. However, I'd rather make use of the original license plate light wires. Has anyone tried these? Do I maybe just have a bad set?
Old 11-05-2006 | 11:43 PM
D2VW14_20's Avatar
Default RE: Trouble w/Light'N Boltz...
MAke sure your positive is to positive and so forth. I hooked up leds to mine and thats all I did (LEDS, it doesnt matter though). If you still have your turns off, try hooking up the bolts to them to see if they work. If you are running both lights into the single wire, it should still be fine. I dont really know why they wouldnt be working unless you did get a bad set.
You can also check by just taking wires and putting them on the bolts and just putting them directly to the battery. IF the works. You can just do that too. Know what I mean????
Old 11-06-2006 | 02:14 AM
dragonium25's Avatar
I've got bolt lights and spliced them to my existing plate light wires. I was running two, but now just one and it's the same thing. Like D2 said, make sure (+) is to (+) and (-) to (-).
Old 06-20-2008 | 10:16 AM
americancycle's Avatar
heres a dealer site of the product, comes with an instuctional .pdf and a frequently asked questions link.
best of luck.
http://www.deicycle.com/License-Plate-Lighting
Old 06-20-2008 | 09:39 PM
willduce's Avatar
dont run them off the battery or they will always be on..just try them jumperedoff the battery to make sure they are good
mikemoore
09-08-2010 02:07 PM
chwelch
08-06-2009 07:26 PM
Chrispy
07-30-2008 04:23 PM
slimgottabike369
05-22-2007 10:57 AM
f4i rider
01-08-2007 02:21 AM
Quick Reply: Trouble w/Light'N Boltz...
