tripometer
can we assume the speedometer is still working since you didn't say it was broken? if it is, then you'll be replacing the cluster. the speedo and odometer/trip on an analog setup use a series of plastic gears and i don't believe you will be able to replace one of them. if you can take it apart, you might get lucky and find an obstruction or a gear out of place.
