Tire pressures?
Many schools of though for this one...In my opinion, a lot will depend on what your weight is and if you travel solo or with a passenger. If your heavy, say over 250lbs, or run with a passenger often, I'd run the max. If your a solo rider and weigh under 250lbs, I'd say you can experiment with lower air pressures. A 100lb rider will have a different need than 300lb rider given the same bike to obtain maximum traction.
If you run too low of pressure for your combined weight, you can feel it in the bike, especially with tracking. the bike tends to wonder and feel odd while trying to go in a straight line. Also, the flickability of the bike can be diminished. It can also lead to odd wear characteristic on the tires such as cupping. Run too high of pressure for your combined weight, and the tires will not conform to the roads surface properly, and traction will be diminished.
Having said those things, If your not an aggressive rider, such as in the corners, there's really no point in running lower than max air pressure. You'd benefit the most from running max pressure and getting better mileage and more life out of your tires. even if your 100lbs, the max pressure will be fine for casual riding situations.
Everybody, always check psi before every ride!
