TIRE FAILURE?
Old Jan 2, 2007 | 06:03 PM
TODDRITZ's Avatar
Default TIRE FAILURE?
Agghhh!! I ACCIDENTALLYrode two-up (300lbs total) for about 4-5 miles with my tires set at 32frt/34rear (foraggresive one-upriding). Will the excessive heat/pressure I caused damage to the tires' carcass and make them unsafe? Also any reccomendations on pressures forhard street riding... Thanks
Old Jan 2, 2007 | 09:45 PM
FordFrenzy97's Avatar
Default RE: TIRE FAILURE?
Won't hurt for 4-5 miles. I run my tires between 35 and 40 all the time.
mpnco's Avatar
maaan, I wish I knew what all that meant lol.........
Old Jan 4, 2007 | 06:36 PM
RCKT GRL's Avatar
You will be fine....
Old Jan 6, 2007 | 08:10 AM
pacemaker's Avatar
Ah, bike tech paranoia, Best you have lost some sleep worrying about it as well, tyre walls are pretty flexable, friction = heat. Tyres a designed to wear to maintain their adhesion. A lot of guys I ride with always run their tyres a few pounds under wots recommended. They believe (and who am I to disagree) that the extra contact on the road, lets the tyre reach its optimal heat range faster. I had to ride with a really flat rear tyre for more miles than you have, and once it was repaired it was fine, no damage to the side walls. I would have been more worried about bottoming out the rear shocks.
cbrpaul
Jan 26, 2013 11:16 AM
BannWorthRulz
F2 Tech
Mar 13, 2012 08:34 PM
ali7up
Sep 5, 2010 03:58 PM
Grove600
Aug 18, 2010 09:13 PM
yoflaco
Jun 21, 2007 01:19 PM
