Tire damage question???
Old Apr 12, 2007 | 09:23 PM
majin ssj eric's Avatar
Default Tire damage question???
Ok, I'm pissed. Last night after a nice little ride I got back home and discovered a razor blade neatly impacted into my rear tire! A razor blade!! Anyway, I removed it and there doesn't seem to be any leak. My question is, is it safe to keep riding on this tire or should I just get a new one? Its the stock Dunlop and it only has about 1000 miles on it so I'd really like to keep it but now I'm afraid it will explode or something at 70 mph on the highway. The cut is about half a cm or so deep but is at an angle(not straight down). Heres a pic:
What do you think?
Old Apr 12, 2007 | 09:30 PM
knightslugger's Avatar
Default RE: Tire damage question???
Got a picture of how wide/deep/location?
Old Apr 12, 2007 | 10:00 PM
I posted a pic but they never work on here. It showed up when I was making the thread but it doesn't show up here. ANyway, the cut is about 4-5 mm and is about halfway between the middle of the tire and the outer edge. The cut is at an angle, not straight down so depth straight down is probably only a couple of mm. I'm nearly certain that the cut is confined to the outer layer of the tire. It is about 1-1.5 cm wide.....
Joker_114th's Avatar
It looks like a blank pic to me???
Old Apr 12, 2007 | 10:22 PM
[IMG]local://upfiles/1261/3B42AD13045E4DB5837365B2CEFEB149.jpg[/IMG]
Old Apr 12, 2007 | 10:37 PM
mccannf3's Avatar
It looks small enough I wouldn't worry about it. Try to remember exactly where it is at and check it frequently, but as long as its not loosing air you should be fine.
Old Apr 13, 2007 | 01:34 PM
jbreit's Avatar
looks shallow enough to me....can you see any threads down in there?...if not, run it.
I might get some tire patch glue to glue that flap down though.
Old Apr 13, 2007 | 03:35 PM
aaron1085's Avatar
looks alright, i'd keep an eye on it though! watch for it to tear at all.
Old Apr 13, 2007 | 04:43 PM
Tahoe SC's Avatar
spit on it and see if it bubbles...sqeeze all around it to see if it bubbles...if not then should be golden.
Old Apr 13, 2007 | 05:54 PM
KingMushroom's Avatar
He's worried about the tire being able to mechanically hold up to it's z-rating, not about a slow leak. For as shallow as the cut is I'd say you have no more worry then tread wear to the same point. You should be ok though.
