Tipped bike, won't start
Old Jul 29, 2008 | 08:23 PM
cyf313's Avatar
Default Tipped bike, won't start
I have a 07 cbr 600. Got tipped, long story. But now it won't start. It will crank but won't fire up. Starter seems to be fine and battery. One thing I did notice is that the left head light does not turn on whenkey is turned to ignitionand ready to start. (Right headlight turns on fine). The left head light does turn on if i turn the brights on. Any clues? Maybe foul spark plugs? It has been a few days, I was thinking maybe the gas has evaporated already? Please help!
Old Jul 29, 2008 | 09:06 PM
rons93rr's Avatar
Default RE: Tipped bike, won't start
isn't that normal for only one headlight to be on at low beam? try putting the bike in neutral an pull the clutch in and then try starting.
Old Jul 29, 2008 | 09:08 PM
rons93rr's Avatar
oh yea, make sure your kickstand is up also. just in case it a safety switch.
Old Jul 30, 2008 | 01:00 AM
justasquid's Avatar
I would make sure your killswitch is in the correct position. Also, there is a bank angle sensor... depending on how hard your bike hit, may be activated. Its a sensor that tells the bike to shut off power to the bike... fuel pump and iginition. If this sensor is bad, it will not start.
Oh yeah, your headlights are fine. Im not sure how you didnt notice it, but the left headlight is low bean only, the right headlight is high beam only.
Old Jul 30, 2008 | 06:13 PM
cyf313's Avatar
test
Old Jul 30, 2008 | 06:14 PM
cyf313's Avatar
Odd how i can't post a paragaragh, but i can post a word and sentence.
Old Jul 31, 2008 | 07:43 PM
600 CBR F4's Avatar
I have the same problem. Hard to describe my problem in another post
Old Aug 1, 2008 | 12:23 PM
mauthman's Avatar
oil probably fouled the plugs
Old Aug 3, 2008 | 12:33 AM
cyf313's Avatar
Charging the battery and bike started right up! Thanks everyone!
Raphius
Jul 5, 2012 02:52 PM
darkyuy
Aug 2, 2011 09:36 AM
nji911
May 18, 2009 12:57 AM
Mastyx
May 31, 2008 05:09 AM
polar1515
Jun 26, 2007 07:15 PM
