Time for some maintnance
Old Sep 29, 2006 | 12:27 PM
gtjimm's Avatar
Default Time for some maintnance
Well, i'm rolling up on 16k miles, and it's time to do some maintnance. I'm gonna change the air filter and change the plugs. Ofcourse I did an oil change, filter change, and lubed the chain. Have you guys replaced anything else around the 15k-20k mile mark? Over the winter I probably should go into a more major overhaul. What do you recomend for my winter project (suspension/enginer/etc?) Just trying to see what I'm looking at getting into over the summer, and whether I should hold of on the filter and plugs until then anyway.
btw, as far as i know filters, plugs, etc are still original.
Old Sep 29, 2006 | 02:32 PM
Tahoe SC's Avatar
Default RE: Time for some maintnance
yea change those...and fork oil too, you should do that once per year or every 10K...
also...you're up for vavle clearance check too...and a throttle sync.
Old Sep 29, 2006 | 07:12 PM
ThisisMickey's Avatar
i am about the same point as well, i changed chain tire plugs and filter, so how do u check throttle sync, i think i messed up my throttle when i torqued it in the opposite direction getting the grip off, and how would u change fork oil? thanks a lot.
Old Sep 29, 2006 | 07:40 PM
Tahoe SC's Avatar
it's actually throttle body sync...need some guages for that or you can home make it.
basically, over time, the pressure in each TB will be off, so you sync it so they are all at same pressure during idle. makes the bike smooth!
as far as fork oil, get the manual, you just need a way to prop up the bike, take off the fork, open them dump out old and in new, but make sure you use the exact amount on both sides...
i'm totally simplifying this so look up the shop manual.
Old Sep 29, 2006 | 08:14 PM
abadfish's Avatar
Let me help you out, Tahoe:
Throttle Body Sync
Valve check
I would also recommend:
Radiator Flush
Replace brake fluids (not just top off) if you haven't done this at 12k miles
You've talked about the fork oil but don't forget that the rear shock also needs to be serviced too.
DBARider
May 3, 2008 10:25 AM
VP
Sep 14, 2007 09:56 PM
DJ SLYKE
Jun 1, 2006 11:45 PM
andyjenks
Mar 17, 2006 01:00 PM
