Throwing code
hey guys, tried to search for this but not finding exactly what i need. I wrecked my 07 1000rr and after gettin it back together its throwin the code 34 (3 long, 4 short). The FI light is also on. I have heard that unhookin the servo can do this but not sure. I have also heard that there is a way to reset the computer. thanks for any help
Unhooking the battery should reset the computer to its original state. As far as I know, that will also remove the codes from its storage.
If your servo is disconnected, try and hook it back up and see if it stops. If you unhooked it for an exhaust mod, usually it is left hooked up to the wiring harness and just cables are removed.
A call to the dealership should tell you what the code 34 is.
