Throttle Response qustion!!!
Okay i went out for a lil ride the other day and my throttle was fine, well when i start to head back home i notice my throttle seems loose. It will reverse its self but i have about an inch of play in it before ill actually start getting some gas moving, im kinda new to bikes so please shoot me an answer!
![Smile](https://cbrforum.com/forum/images/smilies/smile.gif)
Take your tank off and breatherbox and you will see the throttle cable. one is for oppening and one is for closing the throttle. twist the throttle and you will see the one that opens it. Then you will loosen the 2 nuts on the cable on the bracket. pull the slack out of the cable then tighten it all down. you will need to leave a little play in the cable this will help the response of the throttle cable. Once you have done this put it all back together and enjoy the ride
Neu16
05-25-2013 01:18 AM
