Tender
Tender
do you connect the negative pole of the charger to the negative contact on the battery or do you ground it out to the frame? the instructions that come with the tender say that if your bikes system is positively grounded then connect to the battery, but if it is negatively grounded then to go to the frame. i seem to remember it being negatively grounded but idk. 01 f4i btw.
The lower the amperage the better, but I don't think the 1.25 amp charger will hurt your battery as long as it has an auto shut off.
