sticky/jerky throttle
when i got my bike my throttle was sticky and jerky... but i found it was because of the large diameter vacuum hose that go's inbetween #2 and #3 carbs... needs to go over the peice of metal, instead of under it. it was binding up on the circular throttle thing that rotates back and forth... pretty easy fix. but this would only happen if you've been into your carbs or messed with your vacuum lines and accidently put this hose back the wrong way. just a thought.
