steering stablizer
Old May 24, 2007 | 06:00 PM
jasonp's Avatar
Default steering stablizer
will a stablizer stop my frontend from shaking at high speeds 100+ it does it when going over train tracks too at 30mph or so
Old May 24, 2007 | 06:19 PM
Triax's Avatar
Default RE: steering stablizer
If its just shaking that bad just going fast your probably have bent rotor or your front wheel isn't balanced correctly.
Old May 24, 2007 | 07:03 PM
Tahoe SC's Avatar
your suspension may also not be set up well.
with a properly set suspension, you'll get minimal head shakes. a damper shouldn't be used as a band aid for other problems.
Old May 24, 2007 | 07:38 PM
jasonp's Avatar
well my rotor isnt bent. my rim is a little but it only shakes when im hard on the gas and the front end feels like it isfloating. but that doesnt explain why i get head shake going over the train tracks to fast
Old May 24, 2007 | 09:45 PM
alekinci's Avatar
well, with a hard enough flick of the throttle you will make the front end come up. when you hit the gas real hard and your front feels like its floating its possible that you are popping a wheelies. i think you should just apply more weight to the handle bars and shift your position toward the tank.
Old May 24, 2007 | 10:06 PM
outsider8's Avatar
what kind of bike?
Old May 25, 2007 | 02:11 AM
jasonp's Avatar
1999 900rr
lamby
Dec 15, 2007 03:43 PM
Bran Bel
Aug 6, 2007 08:27 AM
AlpineCBR600
Dec 17, 2006 01:19 PM
AlpineCBR600
Dec 17, 2006 01:18 PM
