steering damper
RE: steering damper
OKAY I HAVE A OKLINS ON MINE AND I LOVE IT . IT'S EASILY ADJUSTABLE BUT IT'S ALSO THE MOST EXPENSIVE. IT DOES LOOK KIND OF WEIRD JUST A SHOCK SITTING ON TOP OF THE TANK AND I GET A LOT OF COMMENTS ABOUT IT. A LESS EXPENSIVE ALTERNATIVE WOULD BE A G.P.R STEERING DAMPER AND I HEAR THEY'RE PRETTY GOOD BUT THEY ALSO SIT ON TOP THE LOOKS ARE JUST A LITTLE COOLER. THE BOTTOM MOUNT ONES YOU SAW WERE PROBABLY ON STOCK GIXXERS SUZUKI PROVIDES THE BIKE WITH ONE FROM THE SHOP. BUT MOST PEOPLE ADD ANOTHER BECAUSE THE FIRST ONE IS NOT ADJUSTABLE. (EXCEPT THE OIL WEIGHT)
RE: steering damper
basically, it uses gas or oil pressure to dampen sudden 'jerks' and changes in steering...so takes away little wobbles, decreases the speed of bigger ones, etc.
it's like those cheesy gym machines that use gas cartridges so like the harder you push or pull, the harder it is to move it you know?
RE: steering damper
FordFrenzy97,
I know a couple of guys with steering dampers. One has his on top to put it on display, the other doesn't really care about the looks and has it below the top triple clamp. The only problem I know of with mounting it that low is that my bud had some trouble getting the steering to go from full lock to lock because the damper either hit something else on the bike when the bars were full right, or bottomed out when the bars were full left. In the end, he got it set up so that he was happy with it, but it took some experimentation. Good luck!
