Stator for 01 CBR600F4i
Recently I had the good fortune to receive an 01 CBR600F4i for FREE. That's right, FREE. Yes it runs.
Anyway, After I got some minor repairs done and replaced the battery I realized that the battery was not being charged by the system on the bike. This led me to use a volt meter and measure the voltage at the battery when it was running. Unfortunately, the voltage was very low and the battery was constantly being drained. So now I am thinking I need a new stator or a rectifier. Seeing as how a rectifier has no moving parts in it which equates to less room for failure I finally settled on a stator purchase.
Does anyone know of where I can find a new or refurbished stator for an affordable price?
If any of you guys live in Dallas and now of a place locally or have an online retailer that you use please let me know.
Thanks!
Thanks!
I wouldnt jump right into think the stator is bad. The rectifier is a common problem. Check the wire connections to the rectifier and see if any are melted.
To check the stator, take your multimeter, set it to ohms. Measure across all 3 leads of the stator. measure 1and2, 2and3, 1and3. They should all measure the same. It should be somewhere around .6 or .7 ohms. It may be different on that bike, but they should all be the same. If you have one or two of them out from the other, then the stator is probably bad. If they all measure good, your stator is fine and look into replacing the rectifier.
If you're putting on a Reg/Rec consider going non-OEM and getting a Shindengen FH012AA. Yes you will have some work to do re-wiring it, but it far out performs OEM, doesn't get any where near as hot... and can be found in junkyards and ebay. I think some model R1's had it, as did some of the newer 1000RR's.
It has been discussed here on cbrforum, and also here:
http://www.vfrdiscussion.com/forum/i...howtopic=32021
Several of my riding friends have asked me to do a simple test. Not sure if it will hurt the bike or not so I haven't tried it yet.
They want me to get the bike started and then remove one of the leads from the battery to see if it dies. I have been told that if the bike dies then you more than likely have a stator problem since the stator should be doing all the work and not the battery.
Does anyone know if this sounds right? This seems to be last problem that I need to tackle before the bike is in the right condition to ride on a regular basis. Any information you can give would be helpful.
Thanks to those who have already replied.
that is not right. The stator cannot support the electrical demand of the bike. A bikes charging system is nothing like a car, where the alternator puts out enough to run the car. On a bike, the stator only charges the battery, not support the whole system. So, it will die as soon as you disconnect the battery even with a good stator.
The simpliest test for the stator is measuring the resistance across the leads.
Here is an article which gives a pretty good break down of a motorcycle charging system and why some of the components fail. But I would follow the advice of what the other guys were suggesting.
http://www.scribd.com/doc/8941032/mo...harging-system
I went out today and got a multimeter and measured the resistance across the three leads. 1 and 3 measure at 0.5. 1 and 2 I get nothing at all and 2 and 3 I get nothing so I am guessing the stator is confirmed bad. If this sounds right let me know. If not more suggestions would be appreciated.
slutty62cont
08-14-2005 01:06 PM
