Starting issue
Starting issue
hey guys i have an 05 1000rr that has been sitting up for about a month ( was the last time i started it and was fine )..batery was weak but not dead ..i charged it up still no go...turns over fine but no start..here is what i got so far...no fuel...i turn it on can hear the pump come on and i am pos that the fuel is getting to the rail but whatever allows ther injectors to open is not happening...so i am asuming that i also have no spark...but i have not got that far yet...wondering if anyone has any sugestions...angle sensor?...thanks..tom
RE: Starting issue
Remove the battery, hit it with a 2 amp charge for no less than 8 hours (10-12 hrs, ideally) and give that a try.
I know you said you charged it, but I'm going to say it was a 10 amp/ 30 minute jobbie and that's not going to do it for the battery.
Take 2 amps for 8-12 hours and call me in the morning.
RE: Starting issue
Take a plug out and hook it up to the wire hold it close to the motor or bare metal and see if your getting any spark. Does the engine smell flooded? Try a shot of ether or starting spray from auto zone with the air filter off and see what you get. Just put it down the velocity sacs with the trottle open then give it a crank.
