Standard blinker Problems
Old Apr 10, 2008 | 02:13 AM
freddy478's Avatar
Default Standard blinker Problems
Got caught in rain other day since then the right (rear)blinker has been flashing fastand the front doesn't work at all, left side is fine.Yes checked the globe and swapped with another still has problem. will be checking relays when i get a chance, anyone had similar troubles ?
Old Apr 10, 2008 | 12:05 PM
Lrn2Go's Avatar
Default RE: Standard blinker Problems
Any time this has happened to me, the bulb has been the culprit. Unless something (a wire?) is no longer connected, or if there's some sort of corrosion or something that isn't making a good connection TO the actual bulb itself, that's always been my case. Unless the water shorted something and blew a fuse (not likely) or melted something (not likely)... then I would try another bulb first. Try taking the one that works on the other side out and swapping them. See what happens.
Old Apr 11, 2008 | 10:43 AM
dusterdude's Avatar
what are blinkers?
mrmilan
Jan 27, 2012 01:05 PM
kyleedgeworth
May 28, 2011 06:45 PM
06Tribal600RR
Apr 28, 2011 09:55 PM
ICANDEE
Apr 13, 2010 04:10 PM
PlayMakerStyle
Oct 4, 2009 05:45 PM
