Spray paint removal
Old Oct 14, 2011 | 07:48 PM
daddywilson's Avatar
Default Spray paint removal
I bought a front fender from ebay and the person i got it from had spray painted it. The color under the paint is the color i need so i was wondering if there is a way to remove the spray paint withount having to sand it?
Old Oct 15, 2011 | 06:14 AM
MadHattr059's Avatar
Not a good way and still have an even, uniform finish. Best bet is re-prep and re-paint it.
If you don't have access to a color match, try a contrasting color. That way it looks like you meant to do it not, oops almost right. ;-)
Ern
Old Oct 15, 2011 | 08:27 AM
rpmraper's Avatar
if its just reg spray paint, and good paint under ie. base clear. just use small ammounts of laquer thinner, like use the thinner then rinse it with water then more thinner and water, the reason i say that is because im not sure if it will hurt the plastic, test it out im positive it will take that spray paint off
Old Oct 15, 2011 | 08:53 AM
gunslinger1274's Avatar
Not sure if it was the correct way, but I had the right belly cowling rattle canned by a previous owner. I didn't have thinner, I just used gas. Dumped a little onto a rag and started rubbing it on and the paint started coming off. Worked for me, but the only problem was, that the clear coat came off somewhat.
Old Oct 15, 2011 | 09:37 AM
highwaypatrol's Avatar
You could try using wet and dry emery paper with loads of water that has some Fairy liquid mixed with it. Don't rub too hard and take your time! Test in an area that won't be seen as well when you start. Try 600 grade paper first off and if this is not shifting the paint go for a slightly coarser grade. Patience is the essence!
Old Oct 15, 2011 | 11:12 AM
cobra1000rr's Avatar
gasoline works great on removing spray paint. but he might have sanded it to spray so you might need to repaint it afterwards.
Old Nov 1, 2011 | 01:28 PM
JankCibberf2's Avatar
airplane stripper~~~!!
Petercdcn
Apr 9, 2013 10:13 AM
infamous01
Aug 22, 2007 01:35 AM
Ameer214
How-To: Mechanical
May 21, 2007 11:24 AM
monsta
Nov 5, 2006 08:53 PM
