Spongy Brakes
Old 02-13-2008, 10:10 AM
SurfnSCal's Avatar
Default Spongy Brakes
Anyone dealing with a spongy brake feel at the lever? Tried bleeding your brakes and it does nothing! Upgraded to S/S braided lines, race brake pads and still pulling your lever half way before it starts to slow you down? Yes i know this sounds like an info commercial...but i actually got a tech tip! lol What the problem might be is that the seals for the pistons in your calipers are flexing too much instead of letting the piston slide. So when you are off the brakes the seal retracts the piston too much back and you have to waste 1/2 your lever pull to bring the pads up against the rotors. Now i went to kawasaki update seminar and they told me a tip. What you do is unbolt your calipers, one at a time or both it doesn't matter, one at a time is easier to do it yourself. You unbole caliper and slide it back like you are going to remove it completely. When the brake pads are barely still in contact with the rotor, the edge of the pads. And the majority of the pad is off the rotor, squeeze your brake lever several times. Then reinstall your caliper, it might be alittle tough, but try to avoid wiggling it and spreading the brake pads. Doing this should help the brake feel at the lever. I did it on a Harley i was working on and it made the world of difference....also the Kawi ZX-10R was notorious for this too!
Old 02-13-2008, 05:53 PM
Default RE: Spongy Brakes
wow, neat-o. might have to try this when i put the new pads on.
Old 02-14-2008, 12:37 AM
skubysnak's Avatar
Neat-O????
Old 02-14-2008, 07:23 AM
hey man, iv been coupedup atmy app. for about the last 5 days with my g/f and her sister, the wierdassfemale language rubs off a little-
Old 02-14-2008, 11:26 AM
SpecR's Avatar
So what does it do exactly?
You're basically re-seating the pistons tighter against the rotor, I would imagine?
I have stock, old lines and fairly worn brake pads (OTOH, I have another set of calipers I could switch to...wait, that doesn't help), and even at maximum adjust with the stock lever, it still hits my knuckle when I squeeze it hard with one or two fingers (and not all of them)...
Although I imagine the problem would be fixed if I had the $240 I need for new lines and HH pads.
Old 02-14-2008, 12:13 PM
check ebay- ss lines 60.00, hh pads 40-50.00
Old 02-14-2008, 12:18 PM
SpecR's Avatar
Stuff that cheap usually means they're made by a small (or crappy) company, which means you won't get any money when you have to sue them for making brakes that put you in the hospital.
Old 02-14-2008, 01:17 PM
SurfnSCal's Avatar
SpecR, yeah what it does is push the pistons closer to the rotor, because the seal that it slides on flexes. It does that on purpose, so that when you are done using the brakes it retracts the piston back and allowing wheel to move. But sometimes those seals flew more than others and it pulls back the piston too much which means you have to pull the lever more to make pads contact the rotor. This happens because the pads are wearing but not worn enough for the piston to slide closer. You are just making the piston slide closer to regain that great lever feel. But this is last option, once you've ruled out that everything else is good. No leaks, good components, no master cylinder bypassing, or air in the lines. It was a tech tip the my regional service manual told me during a kawi update seminar. I've used it on several brands and for cruisers and sportbikes. It works, but it is usually the last thing i try after seeing if any air is in the line and rotors are straight and not knocking the pads away.
Old 02-14-2008, 01:21 PM
SpecR's Avatar
My lever seemed fairly stiff when I first bled the brakes, but I noticed the lever was hitting my knuckles after the bike was actually running.
Old 02-14-2008, 05:23 PM
i can tell the difference between name brand and knockoff- i should of specified. i found ss lines and hh pads on ebay from a guy that bought them brand new, never used, half the equip. still in packaging, but for some reason, he bought them for a different model bike, thinking they would work, well they didnt. the pads and lines were model specific for my bike, i bought them. so im saying you might find things like this on ebay (my loss your gain) kinda thing-
Quick Reply: Spongy Brakes
