Speedometer reads "0 mph"
Old Jun 17, 2010 | 12:06 PM
Chrisct713's Avatar
Default Speedometer reads "0 mph"
My 2008 600rr starts and runs fine. When I turn the key on, the gauge cluster "boots up" normally- the tach needle winds up and back down to 0, the speedo scrolls from 150 mph to 0, and all the necessary lights come on. However when I begin riding, the tachometer will correctly indicate engine rpms, but the speedometer does not read any speed, it simply indicates "0 mph." Where do I start to fix a problem like this?
Old Jun 17, 2010 | 08:12 PM
Chrisct713's Avatar
After doing a little research, I decided to go at it myself. I located the vehicle-speed sensor on top of the case under the gas tank. I checked for voltage and one of the three wires didn't show any when I tested it. I followed the wire all the way up to where the main harness plugs into the speedo-cluster harness on the right side of the bike behind the side fairing. There, I found that the wire had pulled out of the connector, essentially leaving an open circuit. Plugged it back in and everything works fine. Just giving this solution info in case any runs into a similar problem in the future.
mrsmobbins101
Apr 1, 2013 11:07 AM
xp3085
F2 Tech
Apr 21, 2011 07:05 PM
jun167
Sep 3, 2009 06:06 PM
KenG
CBR1000F For Sale / Found
Aug 9, 2009 05:20 AM
