speedometer
Old Aug 28, 2007 | 11:44 AM
gdepriest's Avatar
Default speedometer
my 01 f4i has been having an intermitten read out. i can't seem to find a common condition
to when it does it. sometime it won't do it at all. when it does it will just be for a short time.
so far it will only occur one time while i am riding, and the time with out the read out will
be miniminal. any suggestions?
where do i look for a connection.
thanks
Old Aug 30, 2007 | 08:13 PM
trickk034's Avatar
Default RE: speedometer
What read out problems are you having?Iown a 94 so I'mnot familiar with digital read out, but you might want to remove your upper fairings and check under the instrument cluster to see if anything is loose. tighten or plug in anything that might be coming undone.I had a problem with myspeedometer once and i realized that the cable had come unscrewed.
Old Sep 13, 2007 | 09:56 AM
gdepriest's Avatar
hey thanks i will check that out;.
Old Sep 13, 2007 | 08:53 PM
xtremef4i's Avatar
Check for either a fulty speed sensor or a loose connection o at the speed sensor. Its on the back side of the engine at the top of the tranny
Caleb
May 8, 2009 12:08 PM
90f1rider
Apr 23, 2007 12:08 AM
