Speedo fault
The gearing might be changed, makes it faster but throws off the speedometer.
I dont thing they make a speedo healer for the 900rr, but you can put the gearing back to stock if it bothers you.
As the old saying goes 'it depends'.
The chain should be OK, but you need to check the number of teeth on the sprockets and compare back to standard.
If they are different, then that is the reason for the speedo error.
