spark plugs
RE: spark plugs
Unless you're having problems with you current type I'd suggest going back with the same type and heat range. NGK are excellent. As far as how to do it -- only way I know of is to pull the tank and change 'em 1 at a time. If you have a compressor blow out all the crap BEFORE you remove the plugs.
