Slow leak in the Tire
Old Aug 27, 2008 | 12:28 PM
maakif's Avatar
Default Slow leak in the Tire
Hi gang,
I recently noticed that my rear tire is not holding pressure. Over the weekend I checked the pressure and it was 30 psi - I checked the tire for any nails etc but could not find - so thought may be it is because I didn't ride in last two weeks. I inflate the tire back to 42psi and rode 30-40 miles and check the pressure it was still 42psi. Later in the evening I check the pressure again it dropped to 36psi and last night it was below 30psi. The tires have 5500 miles on them and I hate to change the tire.
Any suggestions?? and where do I take it to repair etc.??
Regards,
maakif
Old Aug 27, 2008 | 01:00 PM
Nauree's Avatar
Default RE: Slow leak in the Tire
Take a spray bottle and put water and soap in it. Spray the tire all over and it should bubble where the leak is. Come back to us when you fount the leak.
Old Aug 27, 2008 | 02:32 PM
justasquid's Avatar
+1 on what Nauree said. Just watch close for bubbles anywhere on the tires surface, but also at around lip where the tire and the rim meet. Also, remove your valve stems cap and spray the soap and water there to make sure you don't a valve stem leak.
If it turns out to be a nail or something, I would just change the tire. People plug them and have good success with it. and theycan also remove the tire from the rim, put a patch on the inside of thetire....but I would change it, especially since your at 5500 miles on them. Your not going to get that many more miles out of them anyway. I guess it all depends on the tire, but at 5500 miles, my tires are looking pretty worn out and getting hard to safely make corner transitions.
Old Aug 27, 2008 | 02:57 PM
lonewolfcbr's Avatar
i had a tire with about 1200 miles left to it, i left the nail in and dealt with the slow leak
Old Aug 28, 2008 | 10:21 AM
marc0011's Avatar
Also check the valve stem with the soap and water mix. Some times a valve stem can leak.
Old Sep 8, 2008 | 08:55 AM
binky351's Avatar
i have a question. i have a small nail in my rear tire. its near the center of the tread. the tire only has about 1000 miles on it. i have heard that if you lug or patch that you shouldn't go over about 65mph. is this true? am i ok to repair the tire or should i replace it?
Old Sep 8, 2008 | 06:05 PM
ta8218's Avatar
ORIGINAL: binky351
It needs a patch (from the inside) or one of those plug/patches (also, from the inside, its a patch with a nipple on it that goes into the hole from the inside, too)
My F3 found a nail 300 miles on a new set of tires and I had the rear patched. 155 mph and I'm sitting here telling you about it.
Old Sep 8, 2008 | 08:13 PM
binky351's Avatar
ok thanks. i'm a technician at a car dealership so if i can get the tire off the wheel i can patch it myself.
live4liftin
Jul 24, 2010 10:54 AM
Jin
Sep 9, 2008 12:23 PM
cbrjim07
Jun 29, 2008 08:21 PM
terror
Dec 6, 2007 05:04 PM
unsquare
Apr 22, 2007 11:59 PM
