"Shop Materials" cost....
Old Oct 14, 2007 | 11:55 AM
FHATTCATT's Avatar
Default "Shop Materials" cost....
Relatively upset that after agreeing to take my bike in for major service that I was told after agreeing to the service that there was a $39 shop materials fee. I was told the charge for the service would be $426 + parts... after agreeing to that fee, and giving a $400 cash deposit, I got a printed invoice which also had a $39 shop fee tacked onto it. The shop also is tacking on about $17 worth of shop material fees to their fee to mount and balance 2 tires which I am having done in addition to the major service for an additional fee. I was told that the $39 covered such costs as oil and coolant disposal.... Not sure it costs $39 to get rid of fluids. And not sure what shop materials I am paying $17 for to get a pair of tires mounted.
The most I have ever paid for shop materials to have work done on any car I have ever owned has been $9.
I am pretty close to calling to say that I want all the services cancelled and want my deposit back. $57 worth of shop materials? I have had a day to think more about it and plan to call them first thing tomorrow mornig prior to them beginning any work on the bike.
Anyone else have any input on this one?
Edit: Took a closer look at the invoice and the $39 states that it is for waste disposal on the major maintenance.
Also, I will be keeping the tires they pull off- so they won't be disposing them.
Old Oct 14, 2007 | 11:59 AM
sixhundredrr's Avatar
Default RE: "Shop Materials" cost....
Tire disposal costs money. If they replace the valve stem, that costs money. What is your major service involving?
Old Oct 14, 2007 | 12:19 PM
FHATTCATT's Avatar
ORIGINAL: sixhundredrr
Schedule "A" Service
$102.00 plus taxes, parts, and waste disposal
Recommended every 3,000 miles or 6 months.
Inspect and service battery
Torque all major bolts
Inspect and adjust brakes
Check and adjust tire pressure
Change engine oil and filter
Inspect tire wear
Check for oil leaks
Test ride
Inspect fluid levels
Visually inspect vehicle
Inspect all lights and switches
List future work if any is needed
Schedule "B" Service
$204.00 plus taxes, parts, and waste disposal
Recommended every 6,000 miles or 12 months.
Check air filter
Lubricate all cables
Adjust all cables
Adjust spokes
Adjust drive chain
Lubricate drive chain
Drain crank case breather
Inspect swing arm busings
Inspect swing arm play
Inspect all fluid levels
Change final drive fluid
Inspect cooling system
Inspect steering head bearings
Inspect choke operation
Inspect throttle operation
Lubricate grease fittings
Change or replace air filter if necessary
Inspect and replace sparks plugs if necessary
Plus ALL "A" Schedule Services !!
Schedule "C" Service
Cruisers and touring bikes: $369.00 plus taxes, parts, and waste disposal
All 4 cylinder sport bikes: $426.00 plus taxes, parts, and waste disposal
Recommended every 9,000 miles or 18 months.
Clean and adjust points (where required)
Adjust ignition timing
Adjust valves
Sychronize carburetors
Adjust idle
Test coolant
Flush coolant when necessary
Lubricate swing arm bushings
Check wheel bearings
Pressure wash vehicle when necessary
Old Oct 14, 2007 | 12:48 PM
Scrufdog's Avatar
some of that tire mounting shop material may have been re-greasing the bearings.
Old Oct 14, 2007 | 12:50 PM
PlayfulGod's Avatar
buy/get the manual and do it yourself. All self respected bikers know how to work on thier own bike. Not to mention will save you a ton of cash u can spend on mods, and you will know your bike better.
Old Oct 14, 2007 | 01:26 PM
FHATTCATT's Avatar
ORIGINAL: PlayfulGod
I have the manufacturers service manual. I don't have the time between work and family responsibilities to invest the time needed for going through the major maintenance on thebike. I bought the bike about a month ago with about 14k on the odo. Right now it has about 15k on the odo and is probably due for some service- I don't know the service history on the bike having bought it from a dealer who had no records on the bike. The bike has had the sprockets changed on it at some unknown time in its past- so the mileage on it is higher than it shows, but I don't know by how much.I will be putting my own breaks on it within the next month.
And I don't have too much respect for myself... lol.
davedude44
Dec 13, 2011 09:45 AM
army_soles_803
Apr 16, 2010 11:06 AM
njdjh2o
Mar 18, 2009 03:56 PM
ssweetbro
Apr 22, 2008 11:01 AM
HondaKidF1
May 30, 2006 08:56 PM
