service manuals
RE: service manuals
are you talkin about a service-repair manual like a "Haynes" or the little manual you get when you buy the bike??? cause a "Haynes" type gives you the years it covers for that model and inside the manual it will diferentiat the different years w/ letters like p,m,n etc... for the different years. i hope that helps
RE: service manuals
Generally the factory service manuals will be the same if no major changes except BNG (**Bold New Graphics**). I'm not sure what, if any, differences exist between '03 and '05 F4i.
On e-bay (2001-2005) F4i Paper Manual
RE: service manuals
If there are any differences they won't be in the service sections, usally in the tear down section. Valve inspections/adjustments proceedures will be the same on all shim under bucket motors for the F4I. Double check and call a dealer and ask what the specs are on the 05.
RE: service manuals
It's all the same... I have the factory service manual and right at the top it says 2001-2005. Only difference is in the back there's two seperate wiring schematics, one for 01-03, and another for 04-05, and then in the frame/body panels/exhaust system section there's different sections for the 01-03 and 04-05 versions of the seat, pillion seat, rear cowl, rear fender, and subframes. Everything else is the same for all years, just a different part # for spark plugs for the 2001's
