-   General Tech (https://cbrforum.com/forum/general-tech-9/)
-   -   Seat Removal....not so simple! (https://cbrforum.com/forum/general-tech-9/seat-removal-not-so-simple-121445/)
Allanh Feb 20, 2011 04:09 PM
Hi
I'm a (brand) newbie and just acquired a 1999 CBR600F4 (I think) The owners manual indicates a lock at the rear taillight which you unlock using the ignition key and then remove the seat.......nice & simple, I thought. WRONG! Said lock is nowhere to be found. I've had a good snoop around the bike but can find any clues on a lock or how to remove the seat.
The bike was registered Feb 99, so I guess could possibly be an F3 rather than 4. Is there a different seat removal procedure for an F3; or, if the side panels just below the seat have been renewed, would the lock have been relocated somewhere else ??
Any ideas and comments welcome
Thanks
billetproof97 Feb 20, 2011 04:19 PM
F3's have two bolts on each side of the seat. Not sure about the f4s
scorpionvmu Feb 20, 2011 07:12 PM
i just had same question about my f3 today. what i was told to make the big plastic screw lose on the mid section, right underneath the gas tank. both side rear panels will pop off and the bolts are underneath. once the bolts are off, the seat just pops right off.
jp_greenville13 Feb 20, 2011 08:19 PM
You have an f4 the f4i is the one with the removable seat
gotcbr Feb 20, 2011 11:33 PM
Say what??? The F4 seat comes off the same way as the F4i banana seat.
The F4i split-seat has a rear key lock as well, that unlocks the rear seat...& two bolts under the rear corners of the front seat that allow it to be removed.
Allanh Feb 21, 2011 04:11 PM
Thanks Guys
....thanks to all you guys for your comments. Looks like I need to find and undo the bolts to get the seat off. I'll have a go when I can and post to this thread to update. Might be usefull in future for someone with the same problem
Cheers
Parboy72 Aug 18, 2018 03:25 AM
F4i bannana seat removal
Hi I saw your post on the F4 and F4i bannana seat....how do you remove the bannana seat. Cannot find it anywhere not even my manual. Thanks Gman
edwardzx7 Aug 18, 2018 09:03 AM
I got two pictures of the f3 seat. It has a “hook latch” at the front, but two 10-12mm bolts in the rear. Loosen the two rear bolts, and pull back on the seat. You may need a pry bar bepending on if you ve done work on the bike before.:https://cimg7.ibsrv.net/gimg/cbrforu...f797f2631.jpeg
Two bolts should be hanging down from the seat.
https://cimg8.ibsrv.net/gimg/cbrforu...71c20f4eb.jpeg
Bottom of the seat.
