RR and standard 2006 F4 CDI
Old Oct 24, 2023 | 06:29 AM
Tz250racer's Avatar
Default RR and standard 2006 F4 CDI
Hi,is there any differences on Cdi between the 600 RR and the standard F4 CDI’s?.Components inside,connectors(plugs) etc for the 2006 models.The RR CDI go very cheap on eBay but not for the standard F4.Thank you
Old Oct 25, 2023 | 03:00 AM
dannoxyz's Avatar
Completely different as fuel & ignition maps are completely different between them because engines are completely different. To use RR ECU, you'd need:
- all engine sensors from RR: IAT, MAP, TPS w/throttle bodies, crank & cam sensor
- RR harness
- RR second fuel rail and secondary injectors
- Power Commander w/ignition module to alter RR fuel & ignition maps to work with F4 engine
segraves1
Jun 30, 2011 12:51 PM
Outlaw
Jul 4, 2007 08:39 PM
Chavez
Aug 3, 2006 07:28 PM
CEW149
Jul 22, 2005 03:57 PM
