Right Crankcase Cover
Bikes info is in my sig.
I have a quick two questions, I'm trying to remove my clutch basket and it seems that the last person there didn't believe in torque specs, because when I shift into 6th gear, stick a 2x4 in the rear wheel and try to remove the nut (undid the peening*) the basket still spins, slowly. I tried removing the bolt holding the ignition timing key/rotor using the same method and I could hear the engine turning over and the cylinders "breathing." So anyone have any ideas? will an impact driver help? (sorry no air tools available) and is it ok that the clutch will still spin. All help will be appreciated as I would rather not have to take the bike to the shop to have two bolts loosened for me. Thanks.
Thanks for the ideas and I might just need to fill the bike up with oil and ride it over to my local motor pool. What about one of those electric impact wrenches, would that work? And when I replace the parts I will be using a torque wrench, I have an OCD like fixation about torque specs for some reason. Demon, I'll might just have to take you up on that offer later, I keep wanting to buy a compressor but every time I look in my wallet its empty.
