Replaced Brake fluid
Old Sep 9, 2013 | 03:09 PM
CJardine's Avatar
Track junkie & modaholic
Default Replaced Brake fluid
My front brakes were working flawlessly but it was time to replace the fluid as it was murky and starting to change colors (my only gripe with the ate super blue) I replaced all fluid, bled the brakes and topped off the MC. Now the rear brake is even better however the front calipers have a pretty tight grip on the rotors to the point that the front wheel wont spin. I can move it but once I let go it stops. What would cause this? My calipers should be pretty clean I haven't ridden the bike in too long. So I'm a bit stuck,
Old Sep 9, 2013 | 04:07 PM
gtcole's Avatar
Welcome Crew
Pistons may be a lil dry from lack of use. You sure your brake lever isn't pushing the mc piston? Just a lil pressure will keep the pistons from retracting. Only other thing I can think of with my heat fried brain today, is is it one caliper or both holding it? Could be a bad line...
Old Sep 9, 2013 | 04:26 PM
CJardine's Avatar
That's what confuses me though, is it was working fine before I replaced the fluid.
Old Sep 9, 2013 | 05:06 PM
gtcole's Avatar
Welcome Crew
True, but I know I have changed fluid due to color/moisture and experienced similar issues cause I lodged something in the main line, so it wouldn't release pressure.had to reflush my lines.
Old Sep 9, 2013 | 05:12 PM
CJardine's Avatar
Damn now I gotta buy more brake fluid.
Old Sep 9, 2013 | 06:09 PM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
Are you using some quality DOT4 fluid or cheap stuff from Autozone?
Old Sep 9, 2013 | 07:33 PM
CJardine's Avatar
ATE super blue... will be switching to motul 600 since I can source if I cannot find super blue locally. Apparently its illegal for sale now?? Man a lot has changed since I have been gone... hopefully I can keep my routine of super blue to gold 200 and back through ebay.
Old Sep 9, 2013 | 07:45 PM
kilgoretrout's Avatar
Administrator - Retired
Blue brake fluid? That's pretty cool. I always thought brake fluid was supposed to be black.
The black stuff seems to work just as good in my bike, though.
Old Sep 9, 2013 | 08:16 PM
CJardine's Avatar
Yea the concept was that they offer the same type of brake fluid with two options, one with blue dye the other with gold. It was to help with flushing the old fluid out so when the blue fluid would start to come out you knew that all of the old gold fluid was flushed, and vice verse. It also aided race organizations ensure that fresh brake fluid was in the bike /car. It is now illegal to have blue brake fluid though (or I should say they finally noticed) in America; something about fluid mixup based on what type of fluid your vehicle takes. It sucks cuz now its like $20 a Liter as apposed to the $12 and I sure as heck can't ride hard enough to justify motul 660. At least not yet.
Old Sep 9, 2013 | 10:57 PM
74demon's Avatar
I can still get ate blue. I will check in the morning and let you know what my cost is.
I'm going to pick me up another can anyway. I'm getting low....
