removing the stickers
Old Apr 17, 2008 | 08:35 PM
toddscbr03's Avatar
Default removing the stickers
whats the best thing to remove the stickers offa 03cr 600rr? Thanks 4 the help!
Old Apr 17, 2008 | 09:24 PM
Onarom's Avatar
Default RE: removing the stickers
Heat. heat up the sticker and it will remove with ease. Then you can use goo-gone or honda spray polish to get rid of any left over adhesive.
Old Apr 17, 2008 | 11:59 PM
be vertical's Avatar
peel it and goo gone
Old Apr 18, 2008 | 12:25 AM
NY Erion929's Avatar
hair dryer, use a good amount of heat and peel SLOWLY, then goo gone
Old Apr 18, 2008 | 09:23 PM
toddscbr03's Avatar
I used the hair dryer........beat using my finger nail!!!!! Thanks a bunch, it came off so fast!
Old Oct 27, 2008 | 08:33 AM
va@pacificwebb.com.a's Avatar
Normal 0 MicrosoftInternetExplorer4 Style Definitions table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:"; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} if you need to remove a decal or sticker, don’t use a metal razor blade as its easy to scratch the paint. Depending on the size of the job (i.e. small or large) I know of 2 products. There is a video demo at www.decalstickerremover.com. (one does big areas and the other small areas) Hope this helps. P.S if you need a cheap product that is chemical free to remove the goo or adhesive, try eucalyptus oil (its chemical free and available at most supermarkets)
jpanside@gmail.com
May 26, 2009 04:05 PM
radvoem
Oct 13, 2008 10:09 PM
madmike01uk
Oct 17, 2007 04:28 AM
brian72
Feb 14, 2007 01:40 AM
05f4i16
Aug 17, 2005 12:48 PM
