Relay location
Old Feb 1, 2007 | 12:15 AM
EPNF4i's Avatar
Default Relay location
Is the turn signal relay on an 06 f4i located between the head light assemblies?
Old Feb 1, 2007 | 09:48 AM
cwmc29's Avatar
Default RE: Relay location
On my 2000 F4 the signal relay is located on the right side behind the seat fairing. You have to remove the seat and then the fairing to access the all the relays. I don't know if it is different for your bike, but the look identical.
Old Feb 1, 2007 | 09:54 AM
Idle Hands's Avatar
pretty sure its in the tail under the pass seat. hit the turns and listen for the clicking.
Old Feb 1, 2007 | 10:49 PM
EPNF4i's Avatar
My problem is that my bike is stored for the winter in the inlaws barn so I can't listen to hear the relay. I have the Clymer manual for the f4-f4i 99-03 (bought it because I'm doing the banana seat swap) which shows the relay from 01-03 as being mounted between the head light assemblies. I realize that it stands to reason that this would be the same for 04-06 but I just want to be sure as I'm installing LED's all the way around and the inept mechanic at the dealership I spoke with said " I think it's on the subframe. " He may be right but he sounded so unsure/uninterested. I'm trying to decide whether to order inlines or a heavy duty rely.
thanks and sorry for the long *** explanation.
Old Feb 4, 2007 | 10:12 PM
f4i guy's Avatar
I know for a fact its under the tail section on a 01-03, since I just had it off to install my undertail. Probably same place on your year. Really easy to rmove and check, like 10 min.
Old Feb 5, 2007 | 10:02 PM
EPNF4i's Avatar
Ok, thankyou. I'll probably go ahead and order a heavy duty relay to prevent fast flashing then.
gissmo50
Feb 15, 2010 08:56 PM
westlakeCBR1KRR
Jun 22, 2007 04:07 AM
Reefa
Jan 29, 2007 09:14 AM
redliner25
Aug 25, 2006 04:33 PM
stang930
Jul 6, 2006 12:42 AM
