Regulator/rectifier upside down?
Old Jul 16, 2012 | 12:10 AM
weston123's Avatar
Default Regulator/rectifier upside down?
So I just got a 92 cbr 600 f2. My regulator rectifier went out. I ordered one from ebay and after a while of looking at the picture I noticed that if mounted on my bike the writing on it would be upside down. The prongs are exactly the same so I think it would still plug in, what I'm wondering is would it still function correctly if it was upside down? It says it fits 91-00 f2 f3 f4 is this part gonna work?
Old Jul 16, 2012 | 07:11 PM
justasquid's Avatar
It should be fine.
Old Jul 17, 2012 | 12:46 AM
Shadow's Avatar
Sticker is upside down
Run it - be fine.
Old Jul 17, 2012 | 02:34 PM
weston123's Avatar
Would it cause any problems if the bike was started for a very short period with the regulator rectifier unplugged?
Old Jul 18, 2012 | 07:27 PM
weston123's Avatar
So I got the new r/r and mounted it upside down tested it, it seemed fine went on a short ride went to test again there was a clear jelly type stuff oozing from the r/r and it was hot probably too hot, this ever happen to anyone?
Old Jul 18, 2012 | 07:52 PM
Sebastionbear1's Avatar
Wow! Doesn't sound too good. Was there an earth lead to mount or was it earthed through the body of the R/R? Was it a standard OEM R/R or aftermarket?
And I think there is only one way to plug it in so that shouldn't be the problem.
Old Jul 18, 2012 | 08:54 PM
weston123's Avatar
It grounds from the back of the r/r to a plate on the frame someone did say its not oem, and I just found out that the battery terminal is loose and is causing the bike to die, I'm gonna replace the battery and see what happens
NYKnick1015
Jul 23, 2010 11:57 PM
raiden
Jul 8, 2010 09:18 AM
HurricaneSlim
Jun 28, 2010 03:24 PM
takotruckin
Aug 4, 2008 09:07 PM
