Rear tire leak
Rear tire leak
So my rear tire was down to 5 PSI after getting off the freeway (no idea when that happened and I defiantely checked the reading like 5 times) and after filling it back up the PSI dropped a little bit.
I checked the rim and it looks straight to me and the valve stem isntt leaking any air. I looked and felt around the tire and couldn't find any holes or objects so I have no idea why the tire is losing air.
What should I do next? (the tire is a diablo withroughly3k miles)
RE: Rear tire leak
Replace the tire. Never trust a patch long term on a motorcycle tire. It's just not worth it to risk your life.
If that patch blows, you will have only one wheel holding you up, and the other trying to pitch you off.
A motorcycle is not like a car with 3 other wheels to keep you upright and off the concrete.
Replace the tire....period.
supersnake83
05-28-2010 03:24 PM
berga
F2 Tech
03-25-2010 09:11 PM
