Rear Master Cylinder Piston Stuck
Old Apr 8, 2011 | 09:43 PM
YellowJacket!'s Avatar
Default Rear Master Cylinder Piston Stuck
01 CBR 600 F4i
Bike sat for about 2 years. Took it out today and front brakes were great but had no rear brakes at all. Fluid level is ok but it won't pump or bleed.
Pulled the MC, removed the boot and C Clip and the piston is stuck. Won't budge at all.
I've used compressed air before to blow out caliper pistons - one I never found again - but never a MC piston. Should I continue to try to rebuild or just buy another one? Any suggestions to help fix it are greatly appreciated.
Thanks,
David
Old Apr 8, 2011 | 11:17 PM
87turbobuick's Avatar
i say pull it off and yea apply air to it and shove it out . .maybe fill the caliper with some nasty concoction of atf with motor oil gas pb and brake and parts cleanerr and gum cutter . .i use that mixture for alot of things lol but then yea get the piston out replace nay o rings if necessary clean up the bore and the piston and slap it back together . .not before checking the operation though of course
Old Apr 9, 2011 | 09:01 AM
Thanks,
Tried the brake cleaner first and no joy. Let it sit in p blaster and tried to push it out, again, no joy. Compressed air did the trick.
Now to go fix the hole in my garage wall... :0
David
Old Apr 10, 2011 | 01:03 PM
hahahahaha im sorry i found that funny because i csan just picture it lol. glsad to here it came out . . . . . .hey satleast ur fingers werent in there
Old Apr 10, 2011 | 02:06 PM
LOL... Had the same thing happen when I was restoring my Yamaha except it was the caliper piston. Was about as stuck as stuck could be so I hooked it up to my compressor with an old brake line and opened the air valve. Loud pop and a whiz about an inch from my forehead left a hole in the screen window in my sunroom and never found the piston again.
The next time I rebuilt a caliper I put a metal plate between the piston and caliper. Works much better and I don't have to go looking for parts or buy new ones. :-)
David
Old Apr 10, 2011 | 04:26 PM
a caliper piston is understandable to not find . .me and my buddy were working on his bike . .in the neighborhood trying to fire it up and iot back fired and launched the muffler . . .somewhere . .it was facing so if it qwould go anywhere it would go across the street . .but its not there and we cannot ind it to this day ahhahahahahaha . .i told hime we should put signs up . .have you seen my muffler? with a phone number and a picture lmao
Old Apr 10, 2011 | 08:48 PM
brveagle's Avatar
at the very least i'd rebuild it, if not replace it.
If it seized once, it'll do it again.
Old Apr 16, 2011 | 07:28 PM
Replaced it yesterday as well as the brake pads. Bled teh system with my handy Mity Vac brake bleeder and took her out for a quick ride. Everything is worling nicely.
David
yumoncbr
Jul 28, 2013 08:48 PM
Thad
F4i - Wanted
Feb 24, 2013 03:55 PM
kcrews123
Jul 15, 2012 09:48 PM
weenick
Jun 1, 2011 10:51 AM
