Rear brake 2000 F4
Rear brake 2000 F4
I'm having a little trouble with my rear brake on my bike. When i would apply on the back brake I would feel nothing and then once the pedal was pushed all the way down then the brakes would lock up. So i purchased new back pads and bleed the brake lines took it for a test drive and still the same thing. I called a honda tech and he said it sounds like there is still air in the brake line, that it doesnt sound like anything else. So we bleed the brake line again and nothing. Anyone know what else it could be?
RE: Rear brake 2000 F4
oh and also check to make sure the pistons are not gunked up around the sides. clean that part out and also lube it if you want...but no crazy lube that will fling. you don't want this stuff on your pads or your rotor.
could be possible that the piston is stuck until you put lots of pressure on it then it comes out.
Hayden06F4i
06-17-2008 09:50 AM
