RADIATOR FAN
Old May 30, 2008 | 06:30 AM
gwynsgarth's Avatar
Default RADIATOR FAN
I have a 1989 CBR 600 I am not sure if the radiator fan is working. I have no means of testing the unit and have left the bike running on the drive for ages! no fan. I was just wondering if anybody could tell me how far the temperature gauge rises before the fan cuts in.
Many thanks
Stuart
Old May 30, 2008 | 12:23 PM
lonewolfcbr's Avatar
Default RE: RADIATOR FAN
rises about halfway before kicking on. On my f2 there is a wire running to the switch in front of the rad...jump it to the frame ground on the left side and see if she kicks on with the bike on but not running
Old May 30, 2008 | 01:45 PM
gwynsgarth's Avatar
Fan works when i do that. so is the thermostat switch faulty ? Do not want to blow the head gasket !!!
Old Jun 21, 2008 | 05:52 PM
HondaTech68's Avatar
its easy to test disconnect the wire from the thermal switch on the left side of the radiator it looks like a big plug with a wire coming out of it now take that wire that you just disconnected and touch it to ground with the key on the fan should come on if it does you need a new thermal switch if it doesnt make sure there is 12 volts at that wire if there is its the fan motor if there isnt check your fuses
weston123
Apr 30, 2013 06:30 PM
tpgpz
Jul 19, 2010 01:00 PM
Cytotek
Jun 16, 2010 11:10 PM
f3bika87
Oct 25, 2008 08:09 PM
