Please help
Old Jun 19, 2011 | 04:04 PM
f3 fighter's Avatar
Default Please help
I am running out of Ideas.I bought a cbr f3 1996.the guy I bought it from could not figure out why it would not start after he cleaned the carbs.I found that he had the fuel pump hooked up backwards so that it was pulling gas out of the carb.so I put in new lines new filter, and new plugs as well as new gas.it started right up like a champ.I let it warm up and revved it a few times to make sure the throttle was not sticking, good to go let it sit and run for a few minutes then shut it off for the night.next day tried to start it up to take it around the block and it turns over just won't start. I am getting spark and compression.how do I know I am getting enough gas? Ps battery is fully charged
Old Jun 19, 2011 | 11:07 PM
pacemaker's Avatar
I think its just a process of elimination. My thoughts though, could be the engine got flooded. My F3 is a temperamental beast & if I don't follow normal start up procedure, she don't like it & can end up like yours. Can you hear the fuel pump ticking when you try to start her up? Try to start without touching the throttle, choke on & don't turn the fuel on till she's running (that's my SP).
Old Jun 20, 2011 | 06:04 AM
f3 fighter's Avatar
When it was running I felt the pump running.the plugs aren't dripping only residual fuel when I pull them.I pulled the plugs and turned the motor over to clear the cylinders and put it all back together and nothing.
Old Jun 20, 2011 | 01:56 PM
Monkeybutt2000's Avatar
Is there fuel in the bowls?? Crack open one of the screws and see if fuel drips out.
Old Jun 20, 2011 | 02:16 PM
f3 fighter's Avatar
Yes the re is fuel
Old Jun 20, 2011 | 06:11 PM
HondaJunkie99's Avatar
How do you know which way the fuel pump is supposed to go? I am checking everything on this bike to see what is wrong with it? I cant find it anywhere in the manual.
Old Jun 20, 2011 | 10:34 PM
f3 fighter's Avatar
I looked up the schematic online top hose goes to carb and bottom goes to tank make sure the filter is between thetank and the pump and the arrow is pointing away from the tank and towards the pump
Old Jun 22, 2011 | 06:29 AM
f3 fighter's Avatar
So after letting it sit for 24 hours it started right up.took it around the block.the clutch would not grab till it was all the way out.and in third gear it starts stutering.and then when I down shift and let the clutch out it dies.could this all be related to the clutch
Old Jun 22, 2011 | 10:33 PM
f3 fighter's Avatar
so the clutch needed to be adjusted. much better.the carbs need to be synced i am borrowing a friends carb sync tool tommarrow
