overheated oil??
Old Nov 30, 2006 | 09:43 AM
richterat83's Avatar
Default overheated oil??
Alright, i know i've overfilled the oil in my bike, and, run like that for 3 days. I know this because it's been acting funny. My question is now, after I remove oil to get it to where it needs to be, is the oil that is still in the bike any good? A guy I work with here swears that the oil is no good now because having too much oil in the engine, and, it'll overheat the oil, destroying it. Can anybody confirm that? Thanks in advance
Tylor
Old Nov 30, 2006 | 11:19 AM
fishfryer527's Avatar
Default RE: overheated oil??
Oil will 'coke', but not in a normal motor. I know overfilling is bad for the motor, but I can't imagine oil getting overheated or coked like in a turbo spooling down from 75000 rpm resting on a half drop of oil.
Old Nov 30, 2006 | 11:46 AM
FATHEADS1KRR's Avatar
There shouldn't be anything wrong w/the oil, but being over full could have knocked stuff (carbon, old burnt oil n w/not) loose in the upper part of the crankcase. Changing the oil is pretty cheap, change it if your not sure.
Old Dec 1, 2006 | 03:54 PM
envirocbr's Avatar
Try not to overfill next time dude!
You should try using AmSoil 10W-40 in your bike...you will love that stuff as much as I do!
But there should not be a problem at all with a little overfilling...by the way...how much more did you put over the limit?
Old Dec 1, 2006 | 04:11 PM
woot's Avatar
Crosslink to Original post: https://cbrforum.com/m_196464/mpage_.../tm.htm#197620
Just take a bit of oil off... I wouldn't do an oil change.
How's the bike running now? Did you figure out the clutch issue?
user7891
Jun 5, 2012 02:22 PM
Forcesman
Jun 12, 2011 07:27 AM
lk123
Dec 19, 2009 07:04 PM
Nauree
Aug 30, 2007 06:47 AM
01600F4i
Jun 29, 2005 11:08 PM
