Overheated :O
Old Aug 27, 2007 | 10:54 AM
Nauree's Avatar
Default Overheated :O
My bike overheated right when I got to skool today. IDK why, its the first time it started. I check the coolent overflow and it doesn't have much coolent in there, about 1/4 filled. I dont think that is the problem. Check to see if the oil drain bolt fell out and I dumped all my oil but its all still there. I'm thinking my water pump could be going bad. Its been hitting 100+ in Louisiana lately. Is there an easy way to check my water pump? I'm at skool right now and cant check the manual. Any suggestions?
Edit: It didn't hit the top of the temp. It was about 3/4 the way up. It bogged down and died. Could something else could be causing this?
Old Aug 27, 2007 | 11:02 AM
Nauree's Avatar
Default RE: Overheated :O
Also, wasn't sitting in traffic and the fan did come on.
Old Aug 27, 2007 | 11:08 AM
Mad's Avatar
Mad
A friend had the same problem. He found a good deal on a radiator and bought a new one. Point being check that radiator then the pump.
Old Aug 27, 2007 | 12:15 PM
MikeInCtown's Avatar
If you were just riding and not sitting in traffic and the guage went to 3/4 I would say something is wrong for sure. Coolant missing is also bad and could be a sign of head gasket failure or a crack somehwere. If the coolant is still where it was the last time you looked, I'd say thermostat problem or blockage in the radiator.
Old Aug 27, 2007 | 12:23 PM
Nauree's Avatar
No coolent drained out. I've just been letting it sit low because I planned on flushing the fluid. I just never got around to it. I'm thinking it may be blockage because before this it was fine and I went to florda for a week and it sat. The coolent looks kinda old.
Old Aug 27, 2007 | 12:44 PM
knightslugger's Avatar
Water pump failure? VERY unlikely. You say that it was 1/4 filled (meaning 1/4 of the way to the line?), which means when it cools down, the res is empty... meaning air travels back into radiator where it can make it's way into the engine... fill it up.
Old Aug 27, 2007 | 02:17 PM
Nauree's Avatar
Hopefully its just that. I'm going to change my oil today also. I doubt there should be any coolent in the oil meaning there no cracks in my line. No light smoke has been coming out my exhaust. Hopefully nothing could have been damaged and its just because I've neglicated to do my flush project.
Old Aug 27, 2007 | 07:40 PM
rangerscott's Avatar
Also you can check to make sure the rad cap is holding pressure. You can also pull the tstat and test it.
I dont know what radiator setup is on your bike, but if the rad cap is on the opposite side of your kickstand you can take the cap off (while cold) and start the engine. Rev it a few times and then squeeze the rad hoses to help air come out. Fill up the resevior where it needs to be.
Old Aug 28, 2007 | 03:14 AM
demonchild's Avatar
top it off and you will be fine. sportbikes rarely have trouble with cooling. dirtbikes are a little worse off becasue they get pelted with all kinds of objects. check your hoses, radiator, cap, etc; flush the system, and fill her up.
Old Aug 29, 2007 | 09:57 AM
Nauree's Avatar
I flushed my coolent. I put 3 bottles of waterwetter and the rest distilled water. It still over heating.
