Overheated :O
My bike overheated right when I got to skool today. IDK why, its the first time it started. I check the coolent overflow and it doesn't have much coolent in there, about 1/4 filled. I dont think that is the problem. Check to see if the oil drain bolt fell out and I dumped all my oil but its all still there. I'm thinking my water pump could be going bad. Its been hitting 100+ in Louisiana lately. Is there an easy way to check my water pump? I'm at skool right now and cant check the manual. Any suggestions?
Edit: It didn't hit the top of the temp. It was about 3/4 the way up. It bogged down and died. Could something else could be causing this?
If you were just riding and not sitting in traffic and the guage went to 3/4 I would say something is wrong for sure. Coolant missing is also bad and could be a sign of head gasket failure or a crack somehwere. If the coolant is still where it was the last time you looked, I'd say thermostat problem or blockage in the radiator.
Hopefully its just that. I'm going to change my oil today also. I doubt there should be any coolent in the oil meaning there no cracks in my line. No light smoke has been coming out my exhaust. Hopefully nothing could have been damaged and its just because I've neglicated to do my flush project.
Also you can check to make sure the rad cap is holding pressure. You can also pull the tstat and test it.
I dont know what radiator setup is on your bike, but if the rad cap is on the opposite side of your kickstand you can take the cap off (while cold) and start the engine. Rev it a few times and then squeeze the rad hoses to help air come out. Fill up the resevior where it needs to be.
