oil leak look like from under the gas tank, please help.
Not sure what bike you have or how much oil there is.
Personally I’d prove things to put my mind at rest. Whip the tank off, check your air box and filter. It could just be a build up of crank case oil laced fumes. Check your breather pipe and it’s connections.
Get to that electrical connector and give it a thorough clean up. Are both indicators on one side not working?
Best of luck mate.
Best of luck mate.
Honda f4i '06 oil leak
Best of luck mate.
Best of luck mate.
