oil filter removal tool
Old 10-20-2013, 01:32 PM
adapt63's Avatar
Default oil filter removal tool
evening
cant seem to get a grip of the oil filter. I have a chain type too but it is difficlut to fit. what is the size for the "cup" type filter remover? I m not sure if all these filters are the same size? I have bought an after market filter but pretty sure its thye same as original
thanks in advance
Old 10-20-2013, 02:01 PM
74demon's Avatar
I use a filter pliers. Works every time.
Old 10-20-2013, 04:18 PM
wagzhp's Avatar
You could just drive a screw driver into it. It's a little messy, but it's not like you need to save the filter.
Old 10-20-2013, 04:31 PM
Conrice's Avatar
That's my oil filter remover
Old 10-20-2013, 04:44 PM
Sebastionbear1's Avatar
Chickenfeed.............
I use the JCB multitool
But seriously
I use one of the 'cup' removal tools for the CBR1000Fs
Marked KD 3253 USA. It is 65mm between the flats.
See KD Tools WR 65MM OIL FILT END CP 14PT - Tools - Tool Sets - Mechanics Tool Sets
Cheers, SB
Old 10-21-2013, 05:29 AM
adapt63's Avatar
Yes I've used hammer and driver before but worried might crack the alloy
Old 10-21-2013, 01:49 PM
CJardine's Avatar
Track junkie & modaholic
I've used the hammer and spike method on my bike, on my truck I can just use my hands as long as I'm wearing gloves. Now I have the cup style too but its metal not plastic and it works without fail every time.
Old 10-21-2013, 05:14 PM
adapt63's Avatar
yes ive manage to use hands on the cb 500 but on the cbr shes a little tight, might try those pliers they look pretty cool
Old 10-24-2013, 06:30 AM
mirador1987's Avatar
I ended up using a chain tool until it sliced into the old filter, then it finally gripped.
Old 10-24-2013, 06:41 AM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
I use an oil filter strap wrench. The rubber strap doesn't cut into the filter housing and I just use the wrench to turn it slightly to get things started and then unscrew it by hand.
Quick Reply: oil filter removal tool
