Oil
I just bought a used 2009 CBR1000RR. I am uncertain what brand of oil the previous owner used, but it should have only been one oil change after the factory oil because it only has 5k miles on it.
I am looking to use Mobil 1 fully synthetic motorcycle oil (I am told it's the best?) but it only comes in 10w-40. The manual says it requires 10w-30, but 10w-40 is acceptable in certain temperatures. My stupid *** can't understand the chart they have though. I live in PA - during riding season temperatures range from 40° to 100° F and during the winter it gets as cold as 0°, sometimes a bit lower. Will the 10w-40 work / is it recommended? Also, does the Mobil 1 meet the API/JASO standards?
Thanks!
Thanks!
Thanks!
Thanks!
I have the same oil and it meets the API reqs. and its JASO-MA2 which from my understanding is preferred for your bike. I would recommend finding an oil that is 10w30 theres a reason thats what they recommend event if it can do others. I heard great things about rotella and amsoil too.bbbbb
From your temperature ranges you quote, it may be better to use a 5W40. I'm sure one is available. Looking at the oil viscosities chart in my Haynes manual, 10W40 could be a little heavy for 0 degrees temperatures. It's ok at the higher end but a 5W40 would circulate better on initial start up, but if you can't find an oil with that viscosity use the 10W40. I wouldn't use a 5W30 as it won't protect your engine at 100 degrees, according to my manual. It's ok up to around 90 degrees!
If I were you, I would start my bike from time to time during winter storage, if only to start it and bring it to operating temps.. This will keep everything freshly oiled, and fuel circulating through the system. Don't forget to invest in a Battery Tender. Amsoil is the best and can be bought online as cheap or cheaper than at a retailer, delivered to your door.....Tom
They say just starting and letting it idle for a few minutes is not a good idea. It doesn't get hot enough for long enough to burn off the condensation that forms when starting cold.
Ever notice the drip-drip-drip condensation coming off a car exhaust that was just started on a cold morning? That's the stuff that gets in the oil if it is not brought up to operating temp and ridden for at least 15-20 minutes to burn it off.
