Octane?
Old Jun 14, 2008 | 07:55 AM
Oldest Sage's Avatar
Default Octane?
When I purchased my 88 CBR1000 the guy mentioned he only ran supreme gas in it. I've been using regular gas and have been wondering what the recommendations are? Would I be better off running the higher octane and are there any long term problems associated with uning the lower octane?
Old Jun 14, 2008 | 09:18 AM
JonJon's Avatar
Default RE: Octane?
Ummm yeah you are only suposed to use 93. It is not good for it to run lower octane.
Old Jun 14, 2008 | 11:43 AM
chainstretcher's Avatar
Admin Emeritus & MVN
Default RE: Octane?
There should be some old threads with the research I did on octane ratings. As long as you do not experience any hesitation or knocking upon heavy acceleration then go with what works.
Old Jun 14, 2008 | 11:51 AM
JonJon's Avatar
Default RE: Octane?
Heck I guess that is true. I am actually running 100 octane right now in my bike.
Old Jun 15, 2008 | 10:15 AM
Tahoe SC's Avatar
Default RE: Octane?
lowest possible octane without causing predetonation is what you should run.
any higher octane is a waste of money. bike's ECU aren't smart enough to advance timing or pull timing, etc.
so unless tuned for high octane gas or need it to prevent predetonation (carbon deposits, old bike, etc.), then you're wasting money.
Old Jun 16, 2008 | 12:16 PM
Default RE: Octane?
Thanks guys. I am experiencing some loping at idle and pre-ignition under a heavy load...guess I'll try to bump up the octane and see if that fixes it.
Caccam
Mar 16, 2013 10:20 PM
devo_3386
May 2, 2010 12:00 PM
xcrusader12
Mar 22, 2007 12:27 PM
IDL
Sep 14, 2006 10:46 PM
nutz_oh
Jul 12, 2005 10:17 PM
